21 - 31 of 31 Posts
Discussion Starter #21
So I just wanna make sure I’m understanding this correctly lol one wire on the positive battery terminal and one wire on the ground next to the battery along the inner fender?
yes, wire with the fuse needs to be on the positive for the battery and that ground should already have wires on it. That's the ground I use for all the stuff I added.
Discussion Starter #24
Put the ground connector on the ground on the fender and still no come on gonna keep troubleshooting also my dome lights haven’t been coming when I open the door too
Discussion Starter #25
Tried using the ground where the bolt goes into the inner fender well that has a couple connectors on it
I've had good luck with FASS technical support (via phone) for a couple minor issues I've had. Here's a link with tech support number. Tech Support | Pump Technical Services | Fassride There are also a number on videos online for FASS installs.
Reactions: tryNto and rghavana
Discussion Starter #28
Thanks you guys. Re-read the directions started from square one still no luck might just take it to a diesel shop now my buddies don’t have scanners
Trying to learn
Where you located maybe someone here is close.
I am a newb, but will ask the simple question
have you tested the pump independently? Perhaps you got a bad pump out of the box?
That was suggested in second post, but you can lead a horse to water but cant make him drink.
21 - 31 of 31 Posts
