1 - 2 of 2 Posts
the truck jerks between 1500-1800 RPM, what could be causing this :confused013:? any more or less RPM and it drives just fine. It doesn't seem to be the auto trans since it does it in 3rd or 4th gears and only that RPM range. Thanks, Adam
Read the TC lock up sticky at top of forum lots of good suggestions there. TC locks in both gears and that is about the rpm's mine was doing it at untill I found a loose ground, thanks to the info in that sticky.
1 - 2 of 2 Posts
