1 - 9 of 9 Posts
Well, I'm back with a potential problem. After driving to work, I put the truck in park and it idled up to 1000rpm. Coolant was at 210 (stop and go traffic today) and outside temp was 91 without humidity. Once I shut the truck off and started it again, it didn't do it. Scanned it and no codes, no smoke at idle and it only lightly smokes when i floor it (figured that's normal). Trucks stock, besides exhaust and is an early 04, auto. Any ideas?
did you have cruise control on and bumped high idle on by accident? If it's enabled.
Check for fan wiring damage ,,, and fan codes .
At 210* you should have heard the fan kick in / roar ?
I heard no roar, I assumed the fan worked because when I first start the truck, the fan is on for a few seconds. I've re-routed the fan clutch wiring so it doesn't get caught any more, but i will double check in a few minutes.
So, I checked the wiring and everything was fine. Fan clutch spins with resistance. I did notice the plug wasn't fully in, so I put a zip tie around it. Maybe that was my problem. If it was, I'll feel pretty stupid about it lol.
In the ecm it shows at 225 degrees it idles up to 1k rpm not just when it’s cold
Discussion Starter #8
That's probably why it did it then. I think my fan clutch might not be working. I went for a little drive today and when I got home, I popped the hood and the fan clutch was barely spinning. Truck wasn't as hot as yesterday, but it was a little past the middle point
Gauges in cluster are EMIC(cluster) computer/software generated info, not real accurate.
Should try read direct sensor data with appropriate monitor to get real numbers for diagnosing issues .
1 - 9 of 9 Posts
