Turned the key to on. Everything comes on and then over to start and nothing.. I repeated this 7 or more times and nothing. Checked to make sure it was well into park and that also didnt make a difference. Walked away from it and 30 min later it cranked up like nothing ever happened. The turck has 7k miles on it. My only thought is the starter solenoid.
It could be a loose/dirty battery connection. Check the simple stuff first, othewise I'd suspect you need to see the dealer..
Ops
Ops
A lot of good a dealer is going to do me. If its not acting up them Im wasting my time.. I guess its going to leave me stranded somewhere
I don't know about yours but I have a manual tranny and mine did the same thing
It is called the interlocking ignition switch.
I had this problem, you can turn the key on and all the gauges worked, interior lights are on and bright, do are the head lights, but it will just not crank, click, nothing nada.
I know where mine is located but have no idea where yours is, maybe someone can chile in a tell you, the part for me was 87.00 and 2 seconds to change
Tech Specialist
there is a bracket down by the starter, which kind of covers the fuel return line. there is a wire there (believe yellow with gray tracer) make sure it is not rubbing. have repaired several.
TECH SPECIALIST
There is a software update as per TSB 08-007-08 which involves flashing the wireless control module
