After loading the Smarty I immediatly got codes. I completely removed edge and my power puck,unplugged and plugged in everything the way I was supposed to before loading Smarty ME software. Truck ran fine for a day code free.The next day my truck would not even start:banghead:Codes were P0336 crankshaft position sesor P061C ETC level 2 rpm performance and P0106 Map sensor. Returned to stock loaded software again trying all sorts of SW levels then got these codes only once. P0192,P051C,P0472,P0652,P2228,P0107:shock:Cleared codes and returned to stock. Loaded Smarty again and truck won't start. Returned truck to stock and it starts right up but still runs P0336 Crankshaft pos sen per and P061C ETC level 2 rpm,and of course my egr codes but seems to run fine. Then tried to hook up my power puck and rail pressure gauge on stock and get the dreaded flashing lightning bolt.:confused013: Will only start and run stock.(or as stock as it can be) any advice I'd appreciate. Also nothing was stacked with the Smarty.
