I was cruising home at around 60mph a few hours ago fuel pressure at 14psi. I was slowing down ready to exit ,5th gear at about 13-1400rpm. I hear a weird engine noise, kinda like a knock, then all of a sudden my truck starts to sputter and die on me. I look over at my FP gauge and the pressure reads zero :thud:. I pull over and the truck is about to die any minute, so I shut it down. I wait about 2 minutes then give the truck a bump start. FP gauge reads zero at first and then a couple of seconds later jumps up to 16psi. I start the truck and it starts like a champ. On my way home it felt fine like nothing had ever happened. What happened, Is my injection pump shot? Thanks
BUMP to the top
Mopar1973Man.Com
Run out of fuel?
Loose fuel fitting? (sucking air)
Pump connection? (Plumbing / Electrical)
i just had the same prob, brought it down and said it was sucking air because the stock pump in the tank went, but i still have the BD aftermarket pump on the rail, now its just hard to start like it loses the prime or something
I had 3/4 of a tank, the funny thing is that it ran perfect afterwards. I have a used airdog 150 sitting at home I gotta install. Just have to drain the tank so I can drop it.
