WAG = Ignition Key Switch
You're right about that. At this point I suggest going through all the wiring you can find checking for continuity, clean connections, add a ground from the voltage regulator to the block and another from the body to the frame. Clean the battery terminals. Do a good, thorough check and cleanup on everything electrical you can find until you get it fixed right.I ran a wire from the hot red to the blue and the truck will start and the rest of the electrical works. I had to put a switch in the wire to kill the truck when running. Not right but will work until I can figure it out.
Stop saying "this is my first diesel!" Electricity does not come in diesel or gasoline flavors. :thumbsup:Should I untape the wires along the fender well all the way to the plug at the firewall?
