so i got my hyd assist working over the weekend/days off. my steering box started leaking realy bad so i figured it was time to pull it off for a rebuild and drill the ports for the hyd assist. the ram is an 8" stroke 1.5" bore and 5/8" shaft, worked out pretty sweet. its got plenty of force but is still small enough that the flow of the pump can keep up. i just put the ram in place of one of my steering stabilizers for now. i dont realy like hooking the ram to the tie rod because there is too many pivot points, i would rather have it hooked right to the steering knuckel.so when i put the new front axle in the ram will be mounted to the knuckel, up higher and the fitting will not be right there in the way of getting hit on stuff. also the spacer between the ram and the axle bracket is welded just to give it a bit more meat cuz its only 1/4" plate. so here is some pics.
box drilled and ready for fittings to be welded
fittings w threads machined off ready for weld
box all rebuilt, fittings welded on and caped off
ram installed in place of old stabilizer
rod end hooked to the tie rod
