1 - 20 of 25 Posts
I got the new update and I tryed to reinstall the smarty and I'm getting error code smarty sr. miss 12350331an I need help stuck at dealer
what code is the smarty giving you or saying?
miss 12350331an error. That's what it is saying, and then a second message says error unknown software.
does your truck have the me smarty on it? also you sure you returned it back to factory stock? well not sure on the first code that's coming up. but i think the Unknown software code means that now your truck is running a higher soft ware that what your smarty has on it. what tune do you have on your smarty now? sorry if i am not much help. maybe somebody that knows more about the smarty than me will chime in. i don't know if he can help you if you are deleted but you can try contacting Bryan At smarty and see what he has to say. here is is contact info.
Brian
SmartyResource
SmartyResource Forums
Office toll free: 855-456-7627 855.456.SMARTY
Reactions: BrianAtSmarty
Discussion Starter · #5 · (Edited)
Brian
SmartyResource
Yes I loaded it back to factory before they took the truck. I don't know what happened between them taking it and me getting it back so is there anyway to reset it back to default then redownload my stock program. I have the rmo1l
need to know what file you have on your smarty? but to me sounds like your truck has a newer program than what your smarty has. if that makes sense. sorry not sure on the back to fault setting. your best bet would be to contact Bryan at smarty.
rmo1l? is that the L5 Or the L8 tune? if its the L8 file you have 2 more tunes after that.
Discussion Starter · #9 ·
I think it's the L5 it's been about 6 months since I've updated I found on that works and left it on there until now. Have a hard time finding the new tune
so did you get your truck up and running?
Discussion Starter · #11 ·
28 seconds left on downloading the new software to programer
cool glad you got it fixed. which tune did you end up having to use? really glad we have a sight like this for help and info.:thumbsup::thumbsup: mopar65
Discussion Starter · #13 ·
Me too I would like to thank you and Brian from smarty for all of your guys help. I used the drmo1n
Discussion Starter · #14 ·
All I can say is wow. That tune is amazing. No check engine lights everything is running and working beautifully
Sorry to wake up an old thread but I'm having the same issue .. I was getting the error "unknown software" so I updated from Top Gun Diesel website and now I'm getting the message "miss 12350331an" pls contact madds.. This is on a Smarty Jr and for a 2012 6.7.. What can I do ?
Banned
Your ecm has a newer Chrysler update than the software on your Smarty. One must confirm they are not using an older software. Thanks!
What is the latest version for a 2012 with the ME version??
N is the latest that i know of for the ME software. What version did you load?
I just loaded M and my truck would not accept it.. When Smarty says connect to truck it comes back with error "miss 123450331an" pls contact madds... Wtf ?
Did you recently get your truck flashed at the dealer? If so try the N tune for the 2012 JR.
1 - 20 of 25 Posts
