When I rotate my key of my 2006 to the off position and pull it out of the ignition it is not fully disconnecting the system. The radio still plays and the trip odometer stills shows, also the keyless entry will not allow me to lock the doors because it thinks the key is still in the ignition. Sometimes if I put the tip of the key back in and rotate the barrel assembly I can get it to turn completely off other times I have to shut the radio off and manually lock the doors hoping my battery wont run dead.
Has anyone else had this problem? If not do you think there is anything I can do besides take it to the stealership. Thanks in advance.
