Some one should go thru checks, if issues found best to use Cummins water pump/thermostat and Dodge OEM/Hayden fan , to avoid issues.
50/50 hoat coolant, Distilled water to avoid minerals precipitating corrosion contaminating system.
TEMPERATURE GAUGE READS HIGH. COOLANT MAY OR MAY
NOT BE LEAKING FROM SYSTEM
1. Vehicle overloaded, high ambient (outside) temperatures with A/C turned on, stop and go driving or prolonged operation at idle speeds.
1. Temporary condition, repair not required. Notify customer of vehicle operation instructions located in
Owners Manual. NOTE: Information on dash cluster is displayed based on broadcast information from ECM. DTC will be set for engine sensor circuit concern.
2. Temperature gauge not functioning correctly.
2. Check cluster (Refer to 8 - ELECTRICAL/INSTRUMENTCLUSTER - DIAGNOSIS AND TESTING)
3. Air trapped in cooling system
3. Drain cooling system (Refer to 7 - COOLING - STANDARD
PROCEDURE) and refill (Refer to 7 - COOLING - STANDARD PROCEDURE)
4. Radiator cap faulty. 4. Replace radiator cap.
5. Plugged A/C or radiator cooling fins.
5. Clean all debris away from A/C and radiator cooling fins.
6. Coolant mixture incorrect.
6. Drain cooling system (Refer to 7 -
COOLING - STANDARD PROCEDURE) refill with correct
mixture (Refer to 7 - COOLING -STANDARD PROCEDURE).
7. Thermostat stuck shut.
7. Inspect and test thermostat. Replace thermostat if necessary.
8. Bug screen or winter front being used.
8. Remove bug screen or winter front.
9. Electronically controlled viscous fan drive not operating properly.
9. Check viscous fan (Refer to 7 -
COOLING/ENGINE/FAN DRIVE VISCOUS CLUTCH - DIAGNOSIS AND TESTING)
10. Cylinder head gasket leaking.
10. Check for leaking head gaskets
(Refer to 7 - COOLING - DIAGNOSIS AND TESTING).
11. Heater core leaking.
11. Replace heater core.
12. Cooling system hoses leaking.
12. Tighten clamps or Replace hoses.
13. Brakes dragging.
13. Check brakes. (Refer to 5 -BRAKES/HYDRAULIC/ MECHANICAL - DIAGNOSIS AND
TESTING)
14. Accessory drive belt.
14. Inspect. Replace as necessary.
15. Water Pump.
15. Inspect and replace as necessary.
16. Engine sensor stuck in range.
16. Monitor sensor with DRBIII to verify sensor reading changes increase in temperature.
17. Temperature sensor failed out of range.
17. A DTC will be set.
