1 - 20 of 185 Posts
IL Chapter VP
If anyone would be interested to post some of the ins and outs here in this thread I will be gladly to stick it to the top of the section until a better method is found. I already stuck the head light adjustment thread.
All I ask is to keep the posts in this thread to the topic at hand. If you like a post just thank the person. Keep all the other post out of this thread unless it adds information to the previous post. ( we can then merge the post to make a comprehensive one) This will keep it a very clean thread that has good information in it.
If any one has anyquestions please feel free to pm me about it. I can also copy post and threads into this one if you give me what you want in a pm.
Andy
Tech support junkie
Benifits of doing a exhaust filter delete are-
#1.Oil dilution will be 0% since there is no regening now
#2.Truck now has one less thing system to fail
#3.Enigine will run cooler
#4.Truck sounds much better
#5.Milage increses up to 4mpg
#6.When used with a H&S you get more power
Benifits of EGR system delete
#1.Cleans up engine compartment
#2.No more contaminated oil
#3.Risk of a cooler blow out are no more.
#4.Now have the ability to run a wastgate kit if needed
Egts will get lower as the more parts you add. The 6.7 heats up fast EGT wise this is because of all the restritons cummins used to keep the engine hot. Adding a new airhorn with throttle valve delete will help along with a gridheater delete. Adding a bigger intercooler to it will help cause the stocker is SMALL. Stock VGT turbo is trash i wouldnt ever run that as my high psi twin. If running a twin setup just going with a setup not using the stock turbo. I also cant stress enough how much the 6.7 loves air. If you plan on running a better fuel system someday and making big hp take care of the air issues frist. The 6.7 cant handle heat like the old 5.9s could it just jumps upthere too fast. Running a snow system will help alot too. Alsodont forget to upgrade your trans and clutch if running the g56. Keep in mind g56 useers that heavy duty shafts are a good idea and rec doing them when your do a new clutch i rec a SBC.
Lube needle - napa# 715-12009
OIL filter
Baldwin - BT7349
Fleetguard - LF16035
- LF3972
Fram - XG3976A
- TG3976A
- PH3976A
FACTORY FUEL FILTER
FRAM - FCS10726 or PS10279
Only available from the dealer currently.
Dealer P/N is 68065608AA
FACTORY AIR FILTER
FRAM - CA10261
Baldwin - PA4318
FACTORY TRANSMISSION FILTERS
FRAM - FT1223A (pan)
(NEED SPIN ON NUMBERS)
Cabin Air Filter 2010 Avenger
Mopar - 05058693AA
SEVERE DUTY FILTERS
Filter head - 3930618-S
Water separator
Fleetguard filter - FS1212 or
Baldwin - BF1212
2 Micron Filter
CAT fuel filter - IR-0750
Donaldson Muffler 5" Critical Quiet
M100580
Need to also add bulb numbers to add to the list.
perform service message reset
Perform service is a egr maintenance message to turn it off turn key on step on brake 2 times and fuel 2 times then off.
You will get this message ever 67,500 miles and it is a reminder to replace the crank case breather filter.
Crank Case Vent filter part # CV5200100 (Cummins)
From the Sylvania Bulb Guide...
2010 DODGE Ram Pickup (With 4 headlamp / quad system -- Some SLT's and Laramie):
Low beam headlamp: H11
High beam headlamp: 9005
2010 DODGE Ram Pickup (With 2 headlamp system -- ST and some SLT's):
High & low beam headlamp: H13 (9008)
Other Bulbs:
Parking light: 3157NA
Front turn signal: 3157NA
Rear turn signal: 3157
Tail light: 3157
Stop light: 3157
High mount stop light: 921
Fog/Driving light: 9145
License plate: 194
Back up light: 921
Front sidemarker: 3157NA
Ash tray: 37
Map light: 212-2
Trunk/Cargo area: 921
Coolant performance
The required ethylene-glycol (antifreeze) and water mixture depends upon climate and vehicle operating conditions. The coolant performance of various mixtures follows:
Pure Water-Water can absorb more heat than a mixture of water and ethylene-glycol. This is for purpose of heat transfer only. Water also freezes at a higher temperature and allows corrosion.
100 percent Ethylene-Glycol
-The corrosion inhibiting additives in ethylene-glycol need the presence of water to dissolve. Without water, additives form deposits in system. These act as insulation causing temperature to rise to as high as 149°C(300°F). This temperature is hot enough to melt plastic and soften solder. The increased temperature can result in engine detonation. In addition, 100 percent ethylene-glycol freezes at -22°C (-8°F).
50/50Ethylene-Glycol and Water-Is the recommended mixture, it provides protection against freezing to -37°C (-34°F). The antifreeze concentration must always be a minimum of 44 percent, year round in all climates. If percentage is lower, engine parts may be eroded by cavitation.
Maximum protection against freezing is provided with a 68 percent antifreeze concentration, which prevents freezing down to -67.7°C (-90°F). A higher percentage will freeze at a warmer temperature. Also, a higher percentage of antifreeze can cause the engine to overheat because specific heat of antifreeze is lower than that of water.
(copied from other text)
Tech support junkie
Lets not forget about
propylene glycol OR extended life coolants
This is the type thats used in our trucks this is far superior to green coolant in many ways as ELC has additives already in it and lats for 7 years or 600,000. This is the only coolant i will every use and is what now has become standard in all engine applications. It has the same frezzing properties as green but is just a better coolant
My owners manual states, "This vehicle has not been designed for use with Propylene glycol based coolants. Use of propylene glycol based coolants is not recommended." This is for a 2007.
Maybe something changed for 2010.
Mini / Black Maxx Gauges Explained
Mini / Black Maxx Guages Explained:
Pyro1: Pyrometer feed #1
Pyro2: Pyrometer feed #2
Speed: Vehicle Speed in MPH
Boost: Intake manifold pressure in PSI
RPM: Engine speed in Revolutions per minute
Coolant: Coolant Temperature in Degrees Fahrenheit
Throttle: Throttle position in %
Intake: Intake Temperature (sensor just post air filter) in Degrees Fahrenheit
Barometer: Barometric pressure in PSI
Battery: Battery condition in Volts
ICP: Injection control Pressure (fuel rail pressure) in KSI (5KSI = 5,000 PSI)
Trans Temp: Transmission Temperature in Deg. Fahrenheit
Load: Engine load in %
MAF: Mass Air Flow in Grams / Second
Courtesy of Bentley @ H & S.
Tech support junkie
Want more turbo noise?
Well there are 4 things to do starting with the easiest first.
#1. Intake baffle located in between turbo and airbox. Take it out w/ no CEL and a little louder turbo
#2. Send the turbo compressor housing out to WCC and have them machine the inducer ring some.(DO NOT REMOVE)$75
#3. Buy a S&B intake although the WCC mod adds louder results but works best when used with the intake 289.00
#4. Buy a regular turbo such as a silver 66. Exhaust will be louder and the turbo will scream!!!!
Can anyone confirm if the fog lights 9145 is the same as H10? I have been having a PITA trying to find 9145's but if they are the same as the H10's then I will be very happy as they are in every part store around here.
IL Chapter VP
Discussion Starter #16
Thanks for all the great post guys. Keep them coming and help out each other.
Been getting questions about removing the grill and headlights.
The easiest way to remove the headlights I have found is to remove the grill. I can do it in about 10 mins.
The "Heavy duty" plastic piece is a pita the first time and I replaced the plastic holders with newer style ones that can be reused from NAPA. Once that is off then there is 4 screws to remove the grill (10mm) and to remove the grill you must pull it directly away from the the truck from the bottom with a sharp motion on each side of the grill.
Once the grill is out then remove the 2 bolts on the front/top of each headlight need to be removed as well as a (all 10mm) retaining bolt and clip accessed from each inner fender. Once you have the bolts all out you simply wiggle the light towards the front of the truck until it comes out.
I will post a step by step pictures of how to do this ASAP and add them to this post.
Jay
Will removing this filter cause any problems with warranty?
1 - 20 of 185 Posts
