1 - 4 of 4 Posts
i bought that pressure soliniod from bd i think or who ever and the other day i tightened the bands on the truck but after i tightened the bands i notice just thats adjustment screw on the solioid loosened up so i tightened it back up, but i back out of the garage and when i put in into drive it wouldnt want to move so i firured i tightened it up to much so i took everythign apart again and loosened the adjustment screw off a couple turns but now again it seems like i dont have first gear but when i dropp it off into L then it goes in i think but then when you manuall shift it from L to 2 no gears change till you put in in to drive so i don't know what the F*ck
It is well documented about how to adjust bands. Basically you tighen to 72 inch pounds and back of 1 7/8 turn. Then torque the jamb nut without turning screw. Duh...
You'll get to see how you are at rebuilding now.......
well then thats not the problem cuz thats what i did ;)
in drive it starts in 2nd but if you go into low then it starts in low or it atleast feel like it has the torque in low
1 - 4 of 4 Posts
