I am re-building my transfer case and was going to fill it with Lucas 80W90 gear oil which I believe is acceptable per the service manual and while researching the correct fluid to top off the transmission with I read that some people are putting the ATF +4 in the transfer case as well? Does this sound correct? What fluids do you use in transmission and transfer case?
1993 Dodge W250 4x4 A518 transmission and NP 205 Transfer Case
