1 - 16 of 16 Posts
When u put my truck in reverse or drive sometimes it will kick hard before going in gear. It's really annoying. It doesn't do it all the time so I know it's not suppose to do it I just don't what could be causing the problem. It feel like something may be sticking in my valve body but I do t know alot about transmission. I have also read about u joint. I just need some guidance in the right direction. It did it bone stock, before I did any modifications.
Discussion Starter #2
Help please
Mine does it too. I don't worry too much about it. I thought I had read somewhere on here it had to do with the torque converter.
Yea it acts funny when on lock up too. I love thinking about getting a new converter. It kinda jerk when I throttle up or release throttle in lock up
mine acts funny on the lockup in 5th. Like it hesitates then locks fast. The shift strategy is a lot different than it is on my gf's 3rd gen 6.7.
Mine downshifts like crap too. I'm not too fond of it.
What does it mean when you guys use the term "lock up"? My trans tends to allow the rpm of engine to rev up between shifts. Is that "lock up"?
Mine does the same exact thing. I believe the transmission filter sump pump may be the issue.
It could also be high line pressure in the transmission.
Any input from anyone would be great..
I had this issue and now gone. I will try to explain shortly. I Came to the dealer 3 times. For First they relearned the tranny it helps but not diseappear and finally the issue came back. Second time same thing. Third time I was in a week of vacations and the relearned works fine for all. But I work with my truck and I have 250 gallons water tank in the box. The second week after the relearned the issue start slower to came back another time. And when i work i have to stop for 5 minutes maybe 60 times a day. And I noticed the issue came back when the tank was at the3/4 level and I have a big wave when I stop the truck but just for 5 minutes I did not put my parking brake but I did for the long stop. When I started to put my parking brake at every stop the issue completly diseppear and not came back for now 8 000km. The last guy I talked to the dealer said to me if the relearned help for the issue i had to check my way to drive my truck because it's an auto adaptative and it seems that the tranny try to compensate for something. Maybe if you try put always your hand brake it will helps if it's not cause by a mechanical problem. Wih it helps.
TECH SPECIALIST
"Lockup" refers to the Torque Converter Clutch (TCC), which is a clutch inside the torque converter, between the impeller shell (the part that is bolted to the engine via the flexplate) and the turbine (which is the input to the transmission). The torque converter is a fluid coupling, so normally there is slippage between the engine and trans input. For example, when you're sitting at a stop light (in Drive), the engine is at idle speed (700 RPM maybe) but the trans input is at zero speed (since the wheels are stopped). So there is 700 RPM slip within the converter. This slippage decreases as you bring the vehicle up to speed, but cruising down the highway you might still have 200-300 RPM of slippage.
The TCC is designed to increase fuel economy by reducing (or eliminating) the slippage within the converter. It's often called a "lockup" clutch because it locks the two halves of the converter together. You can normally notice this as a slight dip in engine speed, which sometimes feels like another shift in the transmission.
TECH SPECIALIST
Harsh engagements into Drive (or Reverse) are annoying, but typically they are not a durability concern (the engine torque at idle isn't high enough to do any significant damage). Clunky / banging engagements may be due to worn U-joints, or high engine idle speed.
Another factor may be the length of time the engine was shut down before startup, or whether (or how long) Reverse was engaged (before shifting into Drive). On a Drive engagement, the UD clutch is the applying clutch, so it controls the smoothness of the shift. The primary adaptive (learned) value for UD clutch engagements is the UD Clutch Volume Index (CVI). Actually, there are several UD CVIs, including one for "normal" Drive engagements, and one for "1st" Drive engagements (1st engagement after startup, or after shifting out of or past Reverse). When the engine is off, fluid can slowly drain out of the UD clutch, so the volume of air in the clutch (that the CVI value has to compensate for) may vary depending on how long the engine was shut down. Let's assume that the "1st" N-D UD CVI is set to compensate for a fully drained clutch. If you make a quick stop at a gas station or store (just a few minutes), maybe the UD clutch doesn't drain down all the way, so when you restart and shift into Drive, the CVI is too high (it assumes you need more fluid to apply the UD clutch than you actually do, since the clutch is still part-way full). That could give you a clunky / harsh engagement.
So pay attention to the circumstances immediately before your harsh engagements. Do they happen when the engine is cold, or hot? After a short shutdown, or a longer one? After you've engaged Reverse, or after you've simply shifted from Park (right past Reverse) into Drive?
I probably can't tell you how to "fix" an intermittent harsh engagement, but maybe you can at least better understand what circumstances tend to produce those harsh engagements.
Discussion Starter #11
Will a transmission relearn mess up my mcc on my mini max. Or can I so it with all my mods in tact.
TECH SPECIALIST
What's an MCC?
The quicklearn procedure is programmed into the PCM. All the scan tool does is send a command (to the PCM) telling it to run the quicklearn routine. But the routine is all within the PCM, so I'd expect you could run it without affecting anything else.
Discussion Starter #13
Custom tuning with the mini max. Line pressure was increased a little and shift points were adjusted.
Trans Filter. Change it and you shouldn't see the problem again.
I do not think that has anything to do with it. My truck has done it from day one and I have done a filter and oil change since owning it. Made no difference. I think it is some what normal for these trucks to do on occasion.
I was just came on here to search and start a thread if needed. Mine does the same thing, 2010 with 39K on it now. I took it to the dealer yesterday since its still under the drive train warranty.
Mine is worst when its warmed up. I go from park to drive and it will Lunge the truck forward, so I tried going from park to neutral waiting a couple seconds then into drive and it still lunges. Then I tried from drive to reverse and back and still lunges. It hits into gear HARD. The dealership thinks its a bad u joint but clearly it is not since it don't do it when its cold. My buddy is a service writer at the dealership so I'm going to make sure then go through it all. I'm going to slide under it today or tomorrow and see what kind of play in the gears with moving the driveline.
I think that there is to much play in the ring and pinion cause when you stand outside the truck you can hear it hit into gear with a clanging sound in the rear. I think when you back up it leaves the gears tight in a reverse order and when you go into drive its slapping the gears cause the ring and pinion are tight from backing up. Just a thought.
Does anyone know what the setting is for the ring and pinion??
1 - 16 of 16 Posts
