1 - 13 of 13 Posts
What is causing this, it only rattles in park or neutral?
Is it the tranny, or the transfer case shifter? My transfer case shifter rattles really bad.
Im pretty sure it the tranny, you can only hear it outside the truck.
Same here
Same here, if I am standing in the bed, truck running in neutral, it sounds bad.
Also, when I am in 4X4, it makes some ... noises. Not 100% its normal or not.
1ST GEN MODERATOR
Trans flex plate. Drop the inspection cover and look for metal laying on top of the cover.
If you don't find any metal. Unbolt the converter and slide it back into the bellhousing. Then use a inspection mirror and a flash light and look up around the flex plate mounting bolts. If it is cracked you should see the cracks.
What causes the flexplate to crack, I have put quite a few miles on it but the transmission was pretty much brand new when I bought it in October
1ST GEN MODERATOR
Many things can cause them to crack.
Out of balance torque converter.
Improper torque on converter bolts.
Engine adapter not centered properly.
The flex plate not heat treated properly.
The steel composition was off during MFG of the steel for the flex plate.
Discussion Starter #8
It has been like this for a quite a while, is it possible the whole flexplate could fail or do you think it could wait a couple more months when i convert it probably to a getrag?
1ST GEN MODERATOR
If it does fail you will be walking. That flex plate is the only connection between the engine and torque converter.
Another thing to think about. If it is cracked and letting the converter run in an out of round configuration. It can and will take the front seal and pump bushings out.
It would be better to check it for cracks and repair it now if needed.
I broke a flex plate on a turbo 350 that was mated to a stock reman 350. It broke from the tires catching traction rather abruptly when I got outa the throttle after a burnout. I didn't know what the sound was and drove on it for a couple months before it broke all the way. I would never do that to a tranny again.
Discussion Starter #12
Thanks im gona craw underneath the trck tomarrow and see how bad it is and how much is a new flexplate?
Mine is not that bad!
Wow, I feel pretty good after watching those videos, its no where near as noisy as the tranny noise in those videos.
1 - 13 of 13 Posts
