1 - 4 of 4 Posts
I just picked up a 95 2500 12v and i know nothing about these trucks. The guy i bought the truck from said that it has some performance parts such as a custom fuel plate , larger inj, and lift pump. He also claims that it has a built tranny in it , with 500mi on it(i looked at the trans and it does appear to be new to the truck based on how clean it is). My question is if i let the truck go into od the converter seems to lockup and the truck makes 40psi and pulls pretty good. But if i start from a dead stop and get right into the throttle it pulls for a sec and then feels like it just stops making power and boost , this lasts for about 3to4 sec then it shifts to 2nd gear and seems to pull okay. If i just roll into the throttle in any gear it seems to pull and switch from gear to gear much better. It just seems to not like a quick wot. Is this normal or is there somehting wrong. Any advice would be great thanks
sounds like u may need to do a little adjusting on the pre boost screw to me doesnt really sound likea transmission problem. Does it black smoke a lot before it takes off?
No it doesnt smoke much at all
hmmm im not really sure then my dad has an 05 24 valve truck that was doing something similar to this and took it to a transmission shop and they tightened up the bands on the clutches and it fixed it could be your problem too
1 - 4 of 4 Posts
