1 - 9 of 9 Posts
Does anyone know which line coming from the transmission is hot going towards the radiator and the cold coming the radiator to the transmission. I manage to locate the lines only need to find hot and cold.
I DONT BELIEVE IT!
BUMP.........What kind of trany OIL does it hold????:thud:
What does that have to do with the cooler lines? I need to know which is hot/cold so I can install derale remote fan cooler
:confused:
The FWD one is the hot line.
Thanks navydood, but excuse my stupidity. Would that be the one with the rubber hose or the solid metal line? I have tried to touch them to determine but that’s nearly impossible because of all the heat sorrounding the lines and transmission, and I do not want to buy a thermo sensor for a one time deal.
FWD hose?
If it's anything like the older transmissions, the hot line is the one that comes right out above the shifter linkage, near the front of the transmission. Do they even use shifter linkages anymore?
The line with the thermal probe stuck in it is the hot line.
Thanks Begle1, l will take a look after work and report back to you. I did follow one line and it leads into a very thick metal case that is attached to the side of the block and from there to the radiator. Thanks for the visual aid to:thumbsup
The one that leads to the heat exchanger on the side of the block is the hot line.
Discussion Starter #9
Thank you sir :beer.....thats what I needed to know:woot:
1 - 9 of 9 Posts
