1 - 2 of 2 Posts
I have a small leak on a trans line that goes to cooler. It's the one with the rubber hose in the middle. The crimped hose fitting is leaking. Looked on line and could not find it. Is it a dodge only part. It's to late to call trans shop.
Any ideas.
2004 dodge 3500 4x4
Easy fix. You can remove that crappy leaking "quick connect" line and get some bulk transmission line from NAPA and 4 hose clamps. The aluminum lines are actually beveled near the end so you dont have to worry about the hose popping off. I dont remember what size hose you need offhand, but i can crawl under the truck tomorrow and look if you want to go that route, other wise its $250+ just for the line from Dodge.
1 - 2 of 2 Posts
