Here's the rundown. I have a new 07 1/2 Ram 3500 Dually. The transmission was bad the first day I got the truck. Dodge shipped the dealership a new trans and torque converter. The technician quit after pulling the trans out of my truck. They had another tech replace the trans with the new one.
I drove the truck and everything seemed fine. However, this truck sits for extended periods of time in my driveway. After sitting for a month or so there was a large puddle of trans fluid in the driveway. We finally figured out that the fluid is coming from the top of the dipstick tube. Apparently the trans is pressuring up while sitting and it is then leaking. It DOES NOT do it if you are driving the truck on a regular basis.
It has done this twice. My theory is the vent was plugged from the factory and while driving the trans is venting out the dipstick tube but after sitting for an extended period the fluid is draining back and overfilling the trans and then running out the dipstick tube.
Any suggestions or has anyone else seen this problem? Thanks for your help!!
