1 - 2 of 2 Posts
I have an '06 3500 Diesel which just started puking transmission fluid out from between the rock shield and the transmission. I haven't been able to get it into my shop yet, but the only thing in there is the pinion seal. The dealer said 1.3hrs to change, so I'm wondering if I could get some advice on how to do this. 1.3hrs, you must not have to drop the transmission?
Thanks
Yep, you have to drop the trans and pull the TC out to change the seal. These don't normally just go out. Almost always there is a reason and you will see it when you pull the TC out and look at the hub and check the pump.
1 - 2 of 2 Posts
