1 - 4 of 4 Posts
Next Saturday I go to Brown Diesel and get my Goerend 2 disc torque converter installed.:party018:
I figured I would put in a deep sump pan and change filters while they have it down. I looked on Genos garage and they list 2 filters for the 68RFE. One filter is a spin on and the other goes in the pan. Should I replace both? How often do trans filters need to be replaced?
When i drop my pan, i change both filters. When(if) i get a get a pan that has a drain plug,
and drained fluid is not questionable, i'll change filters every other change.
My Allison trans has 437k miles using this method.:thumbsup: YMMV
What intervals were you changing the fluid at?
1 - 4 of 4 Posts
