1 - 16 of 16 Posts
How much would yall say the NV4500 5 speed transmission and transfer case weigh with and without fluids?
Gonna do the clutch this weekend and i wanna make sure i have a trans jack strong enough to not have to worry about it not being able to get it up.
id prefer to not drain the trans and trans case if i dont have to as im out a job and money is tight right now.
guess the better question is does it weigh under 800 lbs ?
I'm not a transmission tech but I'd bet a large sum that gearbox is half that or less.:thumbsup:
I actually have the same exact question. I already bought the tranny jack with 800 lb capacity.
I have pulled my buddies tranny twice both times left the t-case on and the jack isn't the best but it held it just fine, don't know what weight the jack is so im not much help
yup me to, harbor freight special :lol4:
im goin out there now to take my truck apart so ill let yall know if the trans jack folds or cant lift the tranny here after a bit.
its time to put the full ceramic valair in!!:party018::headbang:
well its less than 800 even full of oil. LOL, cheap harbor freight trans jack picks it up and moves it around just fine.
the tranny weights like 300 pounds tops. . . and the t case weights like 120. . . i picked up the t case and my buddy bolted it on. And we both took the tranny on and off the jack by ourselfs.
i just got done putting a tranny in it weighs about 200ish and transf. 125ish my best guess on the weight
Discussion Starter · #9 ·
kinda what im thinking now that i got it out, guess the transfer case is alot lighter than i expected. damn trany is still on the trans jack under the truck in the driveway. LOL. uess it will go back in on monday when a machine shop opens up so i can get my flywheel turned.
The DLD transfer case weighs 85lbs I just shipped one! 200ish for an auto
the nv should be around 250lbs with the bellhousing.
yup i think my dld shipping weight was 90lbs and a dhd i shipped was about 110lbs
your jack will be fine:thumbsup:
whats the weight of your 271 sportster???
I just weighed the 271 with bolt on flanges and the rear driveshaft flange bolted on is 120lbs empty
If it is the about $139 model it will be just fine, that is the one I bought and pulled the trans and transfer case as one. Sure made putting back together a snap.
(NV4500HD) is 250 lbs and transfer case (NV241HD) is 100 lbs. Thats before adding shrink wrap and a pallet to ship. Both pallets were about 39lbs, and oil drained before shipping. I used a 1100 lb low jack, it did not hesitate a bit. Reason I sent transfer case out is I do not have time to go through it. Wanted gears and chain replaced when reattached to the tranny.
1 - 16 of 16 Posts
