1 - 3 of 3 Posts
Well first off I have a 1995 fourwheel drive with the cummins turbo and 5speed. I was on some wet grass and had to put the truck in four wheel drive and I guess I didnt wait long enough after shifting into 4wd, spun the bolts out of the front drive shaft and busted a hole in the transfercase. It is about the size of a half dollar. What is the case made out of and can I have it patched or do I have to replace the whole unit?
It is made out of cast aluminum. It is pretty chinsey but if you go to a small time welder and he can hook you up. Unless you have the right welder for aluminum.
Thanks alot. I already have it on the trailer I will see if I can get that fixed today.
1 - 3 of 3 Posts
