Breather/vent tube for transfer case. Judging by it hanging down someone forgot to bolt it to upper transmission bellhousing bolt. I think in the 11 oclock position.
Is it important? Or what’s the purpose for it ? To not overheat?
2011 Ram 2500 4x4 6.7 68RFE 4 inch lift
When the fluid gets hot, it expands, so does the hot air and it keeps the seals from blowing out.
The transfer case is usually the lowest vented enclosure on a truck and is a little more exposed. The tube elevates the vent opening so the t-case can be submerged and not flood and puts the opening in a typically dry place where it won't pick up road debris and water.
Reactions: Jesparza174
