1 - 11 of 11 Posts
Must be backwards.
Thanks for opines in advance.
Discussion Starter · #2 ·
Maybe it doesn’t matter, but I have only seen seals where the flat side goes opposite the fluid. This had the flat side towards the fluid. Minor leaking, seal on its way.
Anyone?
Anyone? I won’t get to this until Sunday if I’m lucky, but...
Manual shows installing seal on retainer, then retainer onto transfer case. The seal direction has me perplexed.
Pic of seal I ordered and manual pages.
924266
924267
Well I went out to the garage to take of pic of my transfer case that came off a '95 V10/Auto which I get to go through any time I'm ready, replacing parts to make it fit a 5-speed...
Will have to look into things more but this is how it came:
924298
I appreciate it Loren. I will put it in as yours unless I find info otherwise. It doesn’t appear necessary to remove the cover first.
Spring side always faces the oil right?
Super Moderator
On the Rock Auto pictures it says Dual Lip, so if i'm understanding it correctly it means both sides are the same? It would keep oil from entering and exiting.
Dual lip means two sealing surfaces on the same seal. (Insurance) I’m pretty sure it’s backwards on mine. I never thought of it before, but the reason the spring faces the fluid is the fluid is usually towards the side that gets warmer and pressure builds. As pressure increases the seal is forced tighter. With it backwards, the opposite is true, as pressure builds, the seal folds and could release pressure, and fluid.
I appreciate the responses.
No, that's not how that works.
Double lipped is just added protection against leaks.
A grease seal might hold installed backwards, but an oil seal certainly won't
Super Moderator
Discussion Starter · #11 ·
In case someone digs this post up in the future, the seal is best removed by removing the bearing retainer plate. The seal is a two direction seal, it looks the same on each side.
I can only guess why it is two directional. There is a cavity between the transfer case and transmission with a drain path built into the flange. If you buried the transfer case in mud/water, this would keep the water from entering the case.
1 - 11 of 11 Posts
