I have a question about trans temp. My normal temp is averaging around 115-130 empty and around 140 towing my boat(4000lbs). This seems low compared to what most of these guys are saying theirs run at. Is this bad?
Same here.I run 165 to 168 empty
Same here. It has me concerned really. My 2010 normally ran 140ish empty. I can't ever recall seeing anything over 160 even when towing. This new '12 runs mid 160's, empty, with the dual coolers, and 30-50 degree weather. What temps am I going to see when pulling our 13k+ lb 5er in 80 degree weather?I run 165 to 168 empty
This has what to do with my truck?On the dual cooler package, the added cooler is a water-to-oil cooler that transfers heat to or from the engine coolant (whereas the standard cooler is an air-to-oil cooler). This means that, with the dual coolers, you may actually run hotter than you would with the single cooler (since heat from the engine coolant can actually get transferred TO the trans oil).
Now before you start thinking that the single cooler is better than the dual cooler setup, let me explain. The dual cooler setup is for max tow, and is aimed specifically at trucks which will be doing heavy towing. The big problem you have with heavy towing (from a trans standpoint) is poor cooling at low speeds. When you tow a trailer up a mountain road full of switchbacks, running 15-25 mph with lots of converter slip, there is not enough airflow (through the standard air-to-oil cooler) to keep the trans cool. The added water-to-oil cooler is there because it can remove that heat, even at low vehicle speeds.
By the way, even with the dual coolers, it is still a good idea to use the LOWEST possible gear (yes, FIRST gear if you're running ~20 mph or less) when towing a trailer up a steep grade at low speeds. This will help keep your trans and converter a LOT cooler than if you let it upshift.
Smart man giving you some insight since you clearly statedThis has what to do with my truck?
Idk maybe mine came with the super tranny cooler option when I got it
Mine runs in the 160 to high 180 range unloaded, with the max tow package. I have noticed though that while towing around 14K lbs. that the temps never go beyond the 180s. My truck is a Sept. 2012 build, so I can only assume it has the temp activated check valve. Hope this helps out - I was concerned at how high the temps were unloaded but received info from a few members that it was OK given the late 2012 build date and how the max tow package works.Sometime in the 12 model run, they added a temp activated check valve. Valve stays closed to allow the trans getting to what Ram decides as proper temp. My quess is towing it wont run any hotter. I know on my 11 1500, trans never gets over 140 empty
