1 - 2 of 2 Posts
My 2012 got hit front and rear a few weeks ago. Damaged the ac condenser (trans cooler is mounted on top ) i replaced the condenser/cooler drove the truck the weekend i got it fixed towing my boat no issues, the next weekend trans temp gets to 210* sitting in traffic not moving... truck still shifts fine but temp is 60* higher than normal. It is a 2012 and from what i can tell it doesn’t have a thermal bypass valve. Is there a check valve that may have debris? Any help is appreciated
How severe was the damage?
I would start by double checking that none of the hard trans lines were pinched or kinked from the accident, have you double checked that the fan and fan shroud were not damaged and are functioning?
1 - 2 of 2 Posts
