which port did ya'll stab your trans temp prob into? thanks
My opinion is just get the replacement line and switch out the whole thing.Cooler Line Manifolds at DieselManor
Is this the product you used Punk?
yes,, thats what i have ,,i believe they have another application,,,u can also do the whole line...diesel manor sells the whole line also ,, if u dont feel like cutting the line.....its not a big deal ,,its all compression fittings.......what i did is when i change my fluid and filter ,, i took off the line ,,its kinda impossible to cut in placeCooler Line Manifolds at DieselManor
Heads up guys, the ABSOLUTELY POSITIVELY WRONG place to put the temp probe. Totally useless for any readings that are usable.This is were i put mine. just make sure you put some teflon tape on it. So i doesn't leak like mine did. Kinda got in a hurry.:doh: Passenger side.
It is very crowded going into the trans at that particular spot. Shifter, Band adjuster, TV cable ectHow come someone does not make a small fitting that will go between the line and the tranny, not replacing the whoe line just install a small fitting!! Is that not an option.... i will be installing a tranny gauge when I get back on shore....
Someone does, Genos garage has a simple t-fitting that goes in the rubber portion of the cooler output line. Cutt the line, install the bard t fitting with good clamps and its done.How come someone does not make a small fitting that will go between the line and the tranny, not replacing the whoe line just install a small fitting!! Is that not an option.... i will be installing a tranny gauge when I get back on shore....
