1 - 2 of 2 Posts
I’m looking for a trans plate cooler for a 12 3500 the only one I can find is the AFE blade runner and they are back ordered. My main question is it worth going to a 13 setup with the bigger lines? Does a company make a swap parts kit for that?
You could use a Derale 15870 and the 180 fan stat and do a much better job. My 12 wouldn't run under 198 with the OEM TBV/exchanger. I used 1/2 rubber which is 1/2" ID instead of the steel 1/2" OD. I still have the welded plate exchanger in my museum of worthless parts!
1 - 2 of 2 Posts
