1 - 3 of 3 Posts
47rh Trans 4wd. It has issues shifting, it will almost stall out and you will get a very delayed shift. Nothing seems to effect it. I replaced the TV cable because my old one was damaged. I spent days playing with the adjustment but no matter where i adjusted it, it seemed like it was never even close. I was wondering if maybe it could be an issue with the band or the torque converter. Not sure, just looking for some input.
Have you pulled the pan to see if you have any kind of filings in the bottom? I had a tranny act up a few years back. I lost reverse, but kept driving it. I finally lost forward gears about 10 miles from home. When I removed the pan, there was a bunch of dark looking material in the bottom of the pan. Found out it was clutch material from the torque convertor. Had a new tranny and torque convertor built by Goerend, installed a new tranny cooler and was back on the road.
Sounds like internal issues are messing with your mind.. sorry..
1 - 3 of 3 Posts
