1 - 9 of 9 Posts
I am unable to follow your question. Can you re-state it?
I was driving back and forth to work just fine then yesterday I backed out of the driveway and I had reverse just fine and drive just fine but would not shift out of 1st tried everything. Just all of a sudden
Since you used the word "DRIVE", then you may find what you need in the link in post #2.
Check that your linkage is still hooked up and moving the selector on the transmission. Otherwise it may be the oil pump.
Will it go back into reverse or park?
The 47RE shifts electronically. Probably the shift solenoid failed. Look at the chart shown above.
Discussion Starter · #9 ·
Ats upgraded bracket issue
I had anal aluminum dual CP3 bracket and it broke into a bunch of stuff so I ordered another bracket which was there upgraded bracket and is made of much better material heavy Steel however when I went to install the new bracket It Bolts to the CP3 and to the block or the old one bolts but it relocates the CP3 so the Hardline will not work what is the solution for this problem
1 - 9 of 9 Posts
