Shuttle Shift is what you are experiencing.
Do a search for shuttle shift and you will find out that you need to replace the governer pressure sensor and transducer. There are lots of write ups on here about how to do it.
It is very easy to do. If you can change your transmission fluid and filter you can change these.
FWIW, the 47RE and 48RE are 3 speed transmissions. What feels like 4th is when the torque converter locks up around 43 MPH.
