I have an 02 with a built tranny. Tranny has maybe at most 4k miles on it. Fluid changed after 1000 miles. Just recently it started quick shifting. The 1-2 shift used to be pretty firm now it feels soft then shortly there after there is another shift. We are talking like 1-2 seconds under normal acceleration. Then the truck wont shift again until about 45ish when its going into 4th. Any ideas on what it might be?
the throttle cable bellcrank on the side of the trans has either slipped, or the kickdown cable has broken. Fix it soon, it's a good way to burn out the bands and clutches if you keep driving it.
Ops
How hard are either of these to fix?
BTT i will be trying this monday. Any other ideas or how hard is it to do the previously mentioned?
Look up the factory service manual, its a PDF here on the site somewhere. It will give full details. Easy problem to repair.
Ops
