I just drained trans fluid and replaced both filters. I'm getting a yellow Engine Malfunction Indicator light, and my trans fluid temperature warning light. My owners manual says if that light is on, put the vehicle in neutral and let it run until the light goes off. But when I did that, it didn't go off, and in less than 5 minutes the trans fluid temperature had gone to the high 200's. Neither my owners manual or my Chelton's tell what the safe limits are, but I normally see my trans fluid temp way lower than that.
Can anybody tell me what number I shouldn't go above on this?
I'm looking through the forum at other posts, it seems like either I possibly didn't put the filter on tightly enough, or the thermostat isn't functioning correctly. I can go back and check/ reinstall the filter, and I can check by hand the temperature of the lines coming out (thanks TransEngineer for that info on another guys post!). But this book recommendation of running in neutral until the light turns off- how long and how hot can I let this get before I decide that didn't work? Or should I just skip that recommendation and go straight into reinstalling the filter and checking cooler lines?
