1 - 13 of 13 Posts
the previous owner says he could brake the tires loose from a slow roll and let them go until he took his foot out of it, i cant get it to brake loose on dirt some times did i do something wrong in the trans when i put it back together?
i mean the trans is defntly there its very firm when its put into gear and when it shifts it just doesnt wanna brake loose very often, cept when i run an open turbo
oh and to make this worse i just had a customer come in to my shop and tell me bout his 92 and clams it does the same thing stock
sorry for the long post
thanks
ch
Discussion Starter · #2 ·
can any one else make the clame there stocker will burn em up from a dead stop??
Mine will as soon as the turbo lights from a dead stop, with no brake boost
define pump turned up, cause mines stock except for smoke screw and fuel pin but i was wonder if i did some thin wrong or if this only comes with fuel mods like full power screw
an ideas
ch
fuel screw a couple turns and one on the smoke screw o and advanced timing, thats all
I bleed Diesel
my brother has a 89 727 single wheel completely stock. and it will brake tire loose from complete stop if you mash the throttle
Mine wouldn't even knock the dirt off the top of the tire until i turned up the pump, and changed the exhaust housing.
Mine is bone stock and can smoke the tires from a stop. (If the cable that controls shift pressure is adjusted correctly) I've even turned the low manifold boost screw OUT 2 turns from stock to help fuel economy and it will do it with a little braking until the boost comes up.
Your tires will make a difference. My skinny stock sizes ribs will spin alot easier than some 30's!
Discussion Starter · #9 ·
ok that makes me feel better like stated before, pump is stock besides fuel pin turned and smoke screw, and my tires are deep lug drives so thanks again
how do i adjust the shift cable properly?
ch
Discussion Starter · #10 ·
ok here's what ive come up with you guys that are telling me you can light em up from a dead stop all have th non ic'd motors from what ive read the non ic'd have bigger injectors and a quicker spooling turbo. where the guys telling me they had to do some mods to break em loose are 91.5 or ic'd which have smaller injectors and a slow spooling turbo.
someone wanna tell me if im on the right track??
ch
When my truck was stock I couldn't break a tire loose without a power brake.
Discussion Starter · #12 ·
ahhh there goes my thery
ch
I think you're theory holds some water. The non-intercooled's are peppier stock than the intercooled's. Mine must be tired.
They're all gutless.
1 - 13 of 13 Posts
