Ok here are the parts you will need. If it ain't on the list, you dont need it! This is everything you need to make the interior look factory also.
- Transmission
- Bellhousing
- Shifter, boots, and shifter trim console. Dash pocket that goes in place of the auto flip down cup holders. Trim on the steering column where the automatic shifter was.
- Clutch and brake pedal. Just pedals, they will slip right onto the auto bracket.
- Clutch master and slave cylinder
- Clutch
- Pressure plate
- Flywheel
- Flywheel bolts - these are longer than the auto flex plate bolts.
- Throw out bearing
- Clutch release fork
- New input gear from a 5spd for your transfer case
- Front drive shaft from a 5spd truck
- Transmission soft mount from a 5spd.
Now for the wiring to make it all work. You take the Neutral Safety Switch plug from the old automatic trans. It has three wires. The two outer wires on it are your reverse lights and you have to attach them to the reverse plug on the nv4500 tranny. The center wire you have to run up to the Clutch Safety Switch. It will tap into one wire on the CSS and the other wire on the CSS is to be grounded on the firewall.
No ECM reflash is neccessary.
Hope this helps you and if you have any other questions please feel free to ask.
