Tranny seems to stall before it shifts in all gears. It doesn't feel like its slipping at all, just like its holding on and it feels weird. Does this sound normal for my year or might I have a problem with the TC or clutch or whatever.
Thanks,
Dave
Stalls Shifting
Lonno
I am by no means an expert, however just had a rebuild done on my transmission - HD Valve Body - upgraded converter - transmission was toast before the rebuild.
It played well with others for the first 350 miles , then I noticed the shifting feeling abnormal - stalling as you describe it.
Check gauge came on the next day and threw a low voltage code - intialy thought it was the altenator and was ready to pull the wallet out and lay down more cash.
After digging around more the driver side battery was shot - the altenator was fine - cleaned all the terminals and replaced both batteries - it is fine now.
Not sure if that helps - however that helped me.
Has the KD band been adjusted lately??
