i have an auto 01 and i want to put a nv4500 in my question is i have found a gas 1500 and a gas 2500 both equiped with nv4500 would i be able to use the major parts for the swap from either of these thanks
ya you should be able to since you have the entire truck to rob parts off of!! but heard its alot of work... but good luck with it:thumbsup:
so it doesnt matter that the tranny is from a gas motor thanks
Well not quite O'K. I strongly suspect the bell housing is different on gassers. In addition would suspect the input and output shaft/splines are different from a diesel. Doesn't mean you can't use, just have to look for differences. The bellhousing is first big obstacle.
i figured i might have more problems doin it that way then the original plan (of buying as a kit)which is still the plan thanks
i just read 2500 didnt pay attention to the gas part... sorry, but i would think a nv4500 out of the gas 2500 would be the same as the one in the diesel but could be wrong.
Sorry for the misleading info...:S:
