Searched and learned some good info but have a couple specific questions.
Service manual says to remove starter and crankshaft position sensor. Do I really need to do this? I saw that people do not always remove them.
Second does the TTVA need to come all the way off or can I just rotate to disconnect the wire and then leave it on?
Other than that I think I am good to go as soon as my parts show up
No starter does not need to come off.
starter doesn't need to come off but a barring tool makes it easier to turn the engine over to r&r TC bolts.
available here Cummins 5.9L Diesel Engine Barring Tool-Geno's Garage
and some auto parts stores or online.
might consider taking the ttva off just so you don't bang it on anything and break it.
forgot to mention.
assuming you have a 4x4 take the trans case off first just makes it that much smaller/lighter less to wrestle around.
World Champs!!!
No, don't need to remove start or crank sensor.
Don't need to remove TTVA.
I always drop with t-case on, but install with the t-case off. If you're doing it on the ground, put a big chunk of cardboard down and lay the trans on that when it's out; it slides much easier. You'll need to jack up one side (depending on lifted or not) to clear the frame if you have a deep pan.
Honestly it's a pretty simple job when you get in there. I find jacking on the front driveshaft helps to separate it from the t-case output, beats wailing on it with a hammer.
Thanks.
Luckily I have access to a shop with a lift and tools. Gotta love the auto hobby shop on a military base. Too bad budget cuts are shutting a lot of them down.
So you jack "up" or towards the front of the truck? Do they just rust on or is there something else there I can break?
