Hello,
I purchased a 33.5’ TT back in May. When I went to establish the gain for the TT brakes, I did the usual and found a flat road with no traffic, at 20-25 mph squeezed the levers together on the trailer brake controller and at 10 gain the truck/trailer barely slowed. I replaced a blown fuse in the truck that affected the marker lights on the TT and had to still take it to the Ram dealership when the new fuse didn’t work. They told me they had to reset the computer (Didn’t make sense). But I told them about the above brake controller issue and they said everything checked out. Took the TT to the dealership today to have the brakes adjusted. They did a little adjustment, but the guys showed me when they hooked up a trailer brake meter to my truck. At 10 gain and the brake controller levers squeezed together showing 100%, the truck is sending only 6 volts to the trailer for braking. The service guys said that should be 11-12 in brake voltage.
Went back to the Ram dealership and showed them the attached photo and explained this to them. Their response was the OEM trailer brake controllers can’t be adjusted and it wasn’t the first time they’ve seen this issue. Their plan is to hook up with their meter to confirm and call the Tech helpline to see if anything can be done. So with the TT brakes adjusted, it’s better and slows down but it’s not what it should be IMO. I should be at around 5-6 gain and the TT brakes should dang near lock up at 10 gain. Anyone familiar with this and a potential solution? I haul the TT and occasionally a gooseneck with tractors and want the trailers to work as hard as the truck to get stopped if I have to lock it up. Thanks and take care. Happy 4th!
