1 - 3 of 3 Posts
Looking to level my truck, but everything I've read says that I need to upgrade to an adjustable trackbar. Don't have the $300+ some companies are charging. Just wondering if anyone has the trackbar dimensions so I can cut off the factory ends and weld on some tube adapters with the threaded poly bushings from Ballistic Fabrication. Also does anyone see a problem with going this route? Thanks for any help.
Your factory track bar is solid, so you couldn't do tube adapters. You could cut them off and then drill and tap to accept whatever rod ends you want. If you are going to do all that, I would just ditch the stock one all together and build a new one out of 1.75" DOM and use tube adapters and rod ends.
all dpends on the truck and factory springs , they are all different, DO THE KIT, AND JUST MEASURE HOW FAR YOUR AXLE NEEDS TO MOVE
1 - 3 of 3 Posts
