Trying to install my new Synergy adjustable track bar and having issues getting the old one out.
It appears the bolts have seized to the sleeve inside the bushing. I was able to finally, after smashing a bunch of my fingers, able to get the driver side out but cutting it in half and bashing it out with the hammer. However the passenger side one is stuck as can be. Thing is, you can't get anything on the backside of it to bash it out. Anyone have any tips on getting this thing out? Its really seized in there, can't get a chisel or screw driver or anything under the bolt head to pry it out.
Help please!
· Admin/Mod
I use a Silicone O- ring lube on bolts when installing them in most bushings.
Reactions: rghavana
Well, finally got it out. Took nearly 5 hours and 6 drill bits, but its finally out. Then had to weld up the wallowed hole, but damn it, it's done!
