my dad's '95 cummins auto started shifting in and out of overdrive and in and out of lockup real bad and we checked the voltage going into the TPS and it was 4.97 volts on a Fluke multimeter. we checked the output and it was a shaky .3 volts. so we hacked the sensor all up and finally slotted it enough to get 1.2 volts, but the output voltage was still real shaky. we testdrove it and it seemed to help some so we ordered a new TPS (BWD from Oreillys) and we put it on this morning. the input voltage is 4.99-5.00 but the output voltage is around .08to .10 volts. I thought the output voltage was supposed to be around 1.2????? could the new sensor be bad???? or is there something else causing our problems???
we tested the output voltage from the orange wire to the battery ground. he is testdriving the truck right now and I should know pretty quick weather it is working now
thanks in advance for your help!!!!!
