Check for referance voltage; (+) on the purple/white wire terminal. (-) black/light blue wire terminal. be around 5.0 volts.
Throttle fully closed should be .5-1.5 volts, Moving the throttle lever to open throttle the voltage should change with a max of 3.5-4.5 volts.
Goodluck
Goodluck
