Is there a way to turn on the TPMS sensor option in the EVIC or through the dealer? My 2012 Laramie does not have it as an option however, a friend of mine who has the same truck has it on his. I know I would need to add the sensors to the tires but I'm OK with that.
Unless u don't maintain ur stuff often, u don't want em. Especially if u wanna lower the rears when not hauling heavy.
I don't ever lower the rears when hauling and I am required at times to leave home for extended periods due to work...they make life much easier for the wife and 3yr old!!
2500 had to have them, 3500s do not have to have them...........thus ram did not put it on 3500s. i cannot answer your question about enabling it though.
I see you are a fellow Alberta man. Trust me you DON'T want them, they are a major PITA in the winter. They go off non stop, plus your truck rides like a lumber wagon with 80psi in the tires. If you're not hauling drop the pressure down to 55F and 40R makes a huge difference.
Turned mine off the second I got my mini max installed, good riddance.
they do suck in the winter. this is my 3rd vehicle with the sensors, and none of them have been as finicky as these in the ram. i turned them off with my tuner and dont miss them ONE BIT!
