1 - 2 of 2 Posts
I have a tp38 turbo off a powerjoke with a .84 a/r turbine housing sitting in my shop, I originally used it on a turbo mustang so the pedestal was cut and drilled and tapped for fittings. My question is would I get any gains swapping my hx35 for it? I know it has a 60mm compressor wheel not sure on the turbine. I ran an external wastegate on the mustang would it be ok to run no gate on this if I do use it?
Discussion Starter · #2 ·
no one has any input? I did do a search here and google and found people saying the turbine side was too big with the 1.15 housing, but what about with the .84 housing? I also found out the turbine is around 70mm. some input would be great, I don't want to purchase the adapter (t3 to t4),oil lines, and downpipe if this wont work for my rig.
1 - 2 of 2 Posts
