1 - 3 of 3 Posts
Anyone know if it is recommended to tow with a Power Puck installed? I bought the truck with it on there already. Also, does the truck need to be running or not running to switch it on/off.....thanks for the help in advance.
06 Mega 3500 SRW 6 spd towing a 18' flatbed with a TJ on board.
You will be fine, especially with the G56 tranny. It gives a little boost in power, mainly down low. So it should work out pretty good as it gives the fuel to get a heavy load going from a stop up hill.
Zach
Here is a little info on it
Thanks, I appreciate the info!
1 - 3 of 3 Posts
