Hey guys I have a 97 5.9 12v 3500 dually 4.10 that I am the 4th owner seems to be all stock minus a 4 inch exhaust and a exhaust brake, . I tow heavy .. 21,000 total gooseneck weight trailer behind me. I take it nice and slow and have the best trailer brakes and brake controller as well as upgraded truck brakes along with the exhaust brake... I am in Texas my runs are 3 hrs to Breckinridge, Tx and 6 hrs to Austin hills here and there in the hill country but mild slopes not too long
my question is I don’t want to overwhelm the truck and want to make some upgrades and got the trailer at such a deal deal 5k off anything else available now due to being in the oilfield area and metal prices being through the roof. That I can justify putting around 2-4k in the truck.
what i already have
4K gsk
Pyro
Boost
Temp gauges
Ordering
A smeding 62/65/14
What is recommended for towing ? Past my 4k gsk springs ?
I’m thinking a 10 fuel plate, although I hear the 100 is better at higher rpms?
along with sliding the afc housing forward, tuning the star wheel and smoke screw.
a cold air intake
Some upgraded injectors staying under $800 total for that. What do I need stage 1-2-3-4? Over hears the marine injectors are great but are 5 degrees off on the spray pattern?
I would like to get a smeding drop in turbo upgrade I see them range from $600-1200 however I do not know if it’s required and that all those numbers mean and which I need.. and do you know if I need to match my turbo to everything else I’m doing meaning that would be my last step?
I want to get a good setup but not spend anything I don’t have to to get the performance to pull that trailer without stressing the engine or breaking anything
then obviously I will
Need an upgrades clutch from southbend
I’ve already ordered a 4K gsk.. The exhaust break that came with the truck was supposed to have 60 pound valve springs put on with that exhaust brace I’m gonna have to pull the valve cover and find a way to verify if they already put the 60 pound valve springs in there or not? does anybody have any recommendations as to how I discern 60 pound valve springs from stock springs
thanks, drew
what i already have
4K gsk
Pyro
Boost
Temp gauges
Ordering
A smeding 62/65/14
a cold air intake
thanks, drew
