I’ve had my tater turbo going on 2 years this summer. I have the 67-67 and like it fine . Makes a great sound when spooling . My complaint about tater is that he need to be more careful on double checking turbos before they ship.
Mine the clamp that holes the two half’s of the turbo was very lose . The nut was about to fall off . It was also leaking exhaust pretty good around the back cause of the lose clamp. Tighten it up and the turbo spooled much better .
Problem two, and apparently this can happened to a lot of turbos . Is that the compressor housing was leaking boost. Enough so that when I was boost testing it , I could hear it and physically feel the leak. Had to borrow a snap ring set from my uncle cause the snap ring that holds the housing on was to big for my set. Pulled it off and had to put a small bead of Rtv on it and put it back together. After that it stopped the leak.
For the price I paid it for the turbo I guess I can over look that , assuming the turbo it replaced the fleece performance cheetah turbo is now 1,900$ and my tarter was 1450.
Tarter had a post on his Facebook page saying that the reason he had turbos blowing up was a set of defective turbine wheels if I recall. He has Since switch companies and the problem for the most part went away. I’ve also seem reviews of other similar turbos blowing up from other companies like
Calibrated power solutions. So I guess it can happen from time to time . My cheetah blew up but it lasted 7 years and I believe had a defective turbo wheel that cracked .
